My plans typically have a filter set to read a fire rating parameter and apply the 1-HR rated cut pattern to those rated walls. I can't seem to get the cut pattern to show up on any level of detail besides coarse though. Is there a way to apply the cut pattern to show up on a Fine LOD view?
Gelöst! Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
Duplicate the core material, add the fire tape cut pattern and assign it to the wall core of the fire rated wall type.
Got it, thought you maybe had loaded them in from a source I was not familiar with.
Thanks.
Here are the ones I tweaked for working with the VHA. Change the extension to .pat to open from Revit.
I recently tweaked them so they were not centered so that they would be more visible on short walls.
Hi @ToanDN--
Trying to replicate these patterns, I'm assuming these were made with tightly spaced lines? I tried to do this with a filled region (I was skeptical it would work), and am getting an error creating the pattern from the pyRevit.
This worked for me (this is in thin lines)
Thick lines
Drafting view I created the pattern from (lines 1/256" apart)
