Hello Respected experienced people !!
I need to know about finding topography of a ground surface (help from google earth or any other ) and exporting it to Revit to make it 3D there , so that we could know the cut and fill according to our desire .
1) It would be highly appreciated if you could show me all possibilities as i want to know all possibilities by which i can do my task as i have to do comparison in the end.
2) Also it will be good if you could suggest me some good material , links or papers to read for it and have a broad idea.
There are a couple of workflows in this forum post.
https://forums.autodesk.com/t5/revit-architecture-forum/google-earth-to-revit/td-p/6853891
What version of Revit are you using? If 2018, I would highly recommend CADtoEarth. Unfortunately, not available for 2019 or 2020, but you can create the Toposurface in 2018 using the add-in, and then upgrade the RVT to 2019 or 2020.
https://apps.autodesk.com/RVT/en/Detail/Index?id=4910606560103189779&appLang=en&os=Win64
Use your Previous Version Rights. You are allowed to use 3 versions. Download and install 2018 and then install the free CADtoEarth Add-in from the Store. I would if I were you.
