One of the warnings in the model is "Multiple Areas/Rooms are in the same enclosed region", which gives us the following info: workset, name, room number, ID. Naturally, any element can be selected by ID, and thus I can see in the project browser that the room is placed on a specific floor, in my case it is the 6th. Scheduling the Areas/Rooms in question gives also an exact area and perimeter.
We have hundreds of views in the project, where is this room exactly, on which plan? This is a detail region, so it cannot be isolated in 3D, and clicking "show" either in the warning message or in schedule does not find a good view (like, of course, when did it ever?). But the room is there somewhere. How can it be found? Should be easy enough?
Gelöst! Gehe zur Lösung
Gelöst von b.ross. Gehe zur Lösung
on the schedule consider adding a level parameter - this will allow you to identify which level the unenclosed room appears on, create a plan of that level and highlight on that plan.
