Finding a Revit Project with DWG export settings
9 ANTWORTEN 9
Nachricht 1 von 10
vkeller
435 Aufrufe, 9 Antworten
We made a lot of DWG export settings in a Revit Project. They forgot what Revit project that they made it in and they have 100’s of projects on their drive. Is there any way he do a search to find the project with all of his export settings?
9 ANTWORTEN 9
Nachricht 2 von 10
martijn_pater
als Antwort auf: vkeller
Wouldnt it be easier to just recreate/reset/set the dwg export settings?
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2019/EN...
Nachricht 3 von 10
vkeller
als Antwort auf: martijn_pater
Problem is they don't want to recreate all the export settings. They wanted to know if somehow to do a search to find the project with their exports settings.
Nachricht 4 von 10
hmunsell
find the set of DWG's that was made, find the project number/name. hopefully the projects are organized on the server and that should narrow the search for the revit models.
Howard Munsell
Nachricht 5 von 10
vkeller
als Antwort auf: hmunsell
Thank you for your suggestion. I will find out to see if this will work.
Nachricht 6 von 10
vkeller
Just to give you an idea of the magnitude of that task: I have 135 archived Revit projects. Going through each one and comparing the .rvt with .dwg files will be very tedious. I sure hope there is an easier way.
Nachricht 7 von 10
Don't you store the DWGs in folders with Project name/number?
Nachricht 8 von 10
hmunsell
if you can find the DWG's/PDF's, you should also be able to get a date range the project was worked on and possibly who worked on it.
Howard Munsell
Nachricht 9 von 10
vkeller
I don’t understand what you’re suggesting. Whereas I have 135 Revit projects to search, I have literally over a thousand .dwg files. Can you help me understand the logic in searching the .dwg files?
I am hoping for a better solution.
Nachricht 10 von 10
Mark.Ackerley
Heya,
I presume you know what the settings are called? Or some other property? A lot of methods & properties are exposed in the API...
https://www.revitapidocs.com/2015/815928cf-5c0e-ceda-c9ac-a3b1c992e27b.htm
I’m a Dynamo user so I would use Dynamo... Background open the files, get their Export Settings, Filter the File where a setting == the name... Perhaps 10 nodes?
If you’re not comfortable with that workflow, you’ll probably spend longer getting it to work than the manual method, but it would be more fun :leicht_lächelndes_Gesicht: Here’s most of the nodes you’d need...
https://forum.dynamobim.com/t/batchexport-dwf-linked-files/13852/8
Hopefully that’s of interest!
Mark
