Sometimes it is difficult to find an opening that I cut in a roof. Most of the time if I hover over it with my mouse it will highlight.
Other times I simply cannot find it, even if I try to in different views.
Is there a way to locate cut openings every time, like a command?
Is is visible when you select the Element that it is intersecting with and cutting?
...but, there is no special command to reveal it other then Unjoin. I feel your pain though. It is difficult to find it sometimes for all of us.
If you are using the built-in opening tools from the ribbon (By Face/Shaft/Vertical/Wall/Dormer) you could select multiple elements by a crossing window and then Filter out selection and check only the opening
Otherwise you have the following options
My problem turned out to be that the shaft opening was set to a different workset than the main workset1 I was working on, and that workset was turned to NOT VISIBLE. Therfor, it was completely unavailable because It was turned off.
Check your worksets. ![]()
