Find railing tag
6 ANTWORTEN 6
GELÖST
Nachricht 1 von 7
4837 Aufrufe, 6 Antworten
Find railing tag
1) Hello, I find a railing tag but don't find it. Railing is "ringhiera" in italian.
if I go on "annotation" ==> "architecture" i don't find it.
2) Other question ==> how can I instal English libraries?
I have only italian of that, thank's.
6 ANTWORTEN 6
Nachricht 2 von 7
RDAOU
als Antwort auf: Anonymous
You can find it under :
C:\ProgramData\Autodesk\RVT 2020\Libraries\US Metric\Annotations\Architectural
I think you are using 2015...Change the read to match your Revit version and language of the library you have example RVT2015 ...attached is the family if you can't find it
If you want to download the English Libraries, you can run the installer from program files/add remove programs
Once the installer launches >>> select add/remove Features>> follow screen instruction till you get to the screen where you check the content libraries to download.
NOTE: check all the new you want to install + the ones you have already installed
Or watch below screencast …. Credits to @Lance.Coffey
0d541a66-4f17-4f4c-ae75-d71687a0598f,640,620
Nachricht 3 von 7
@Anonymous : if all else fails, it's not the end of the world.
Do you have a Multi-Category Tag? If so, open it and re-categorize it as a Railing Tag, Edit the Label as needed, and then save tag under new name and load into the Project.
Your work is done.  Your Project now has a Railing Tag. You probably even have enough time left over to go catch a movie matinee with the new cute hire.  Maybe not.
Nachricht 4 von 7
RDAOU
@Anonymous  Did you manage on this one
Nachricht 5 von 7
als Antwort auf: RDAOU
@RDAOU  no, I left it open.
I search now your path but doen's go. Now I've install Revit 2020.
For the rest I left unfinished.
Nachricht 6 von 7
RDAOU
@Anonymous
That's where my libraries are lol
For 2015 go to  C:\ProgramData\Autodesk\RVT 2015\Libraries\US Metric\Annotations\Architectural
For 2020 go to C:\ProgramData\Autodesk\RVT 2020\Libraries\US Metric\Annotations\Architectural
While installing 2020 don't forget to make a check mark on all the libraries you want
Nachricht 7 von 7
@RDAOU  with your path doesn't go.
With stop to libraries go but is empy.
Think have to donwload libraries (IT and US).
