trynig to open a project with previous version than usually use from ICS process.
Don't find dwg file I import.
If open a new file and thanb I improt dwg file i find in the center of project (attachment3).
Solved by ToanDN. Go to Solution.
Yes but if import a dwg file is put in center of project like att 1?
Beacuase if do the same but with file on IFC version there isn't (atta 2).
