filters
11 ANTWORTEN 11
GELÖST
Nachricht 1 von 12
tpreisler
659 Aufrufe, 11 Antworten
filters
Hi, can you please show how to create a filter to an elevation view that should show dotted all foundation walls and footings.
Thank you
11 ANTWORTEN 11
Nachricht 2 von 12
bimscape
als Antwort auf: tpreisler
Basically there are two parts to creating / using Filters:-
1) Create (ie Define) the Filter. This where you define the criteria that will trigger the Filter. It is generally where you are looking for a specific parameter value in a specific Category. When this meets the criteria, the Filter is active
2) Define the Graphics / Visibility Overrides that you wish to take place in that specific view- WHEN the Filter is active. This is where you set a dashed linestyle for your Foundation Walls, when see in elevation.
Hope this helps a little?
Kind regards,
Ian
Author of The Complete Beginners' Guide to Autodesk Revit Architecture (free online course)
Nachricht 3 von 12
Normally you show the silhouette outline of the underground structural as hidden lines behind the topo.  If that what you want to do then there is no need to use Filter.
Nachricht 4 von 12
tpreisler
als Antwort auf: ToanDN
Right, but when topography is on it doesn't let me see the foundation.
Nachricht 5 von 12
- Temporary hide the topo or change it to transparent
- Use Linework tool to override the below grade lines to Hidden
- Restore the topo
Nachricht 6 von 12
What about just using the Show Hidden Lines Tool?
...or Graphic Override by Element? Foundation walls' projection lines=dashed, Topo=100% transparent.
Nachricht 7 von 12
tpreisler
Thanks, i think in my case which i have a lot of foundation walls and different levels it would be easier just to filter that foundation wall should show dotted.
Can you show how to do it.
Nachricht 8 von 12
Pick a parameter that distinguishes the ones you need to filter from the rest, whether it is Type name, Level, etc... Then create a filter assigned to the category with the parameter as the criteria and add it to the view. Highlight that filter under filter tab and you can override its graphics how you want. Often you need more than one filters to get what you want.
Nachricht 9 von 12
tpreisler
Hi, thanks for the info. I tried doing these filters but i can't make it work (only foundation not all walls) would you be able to show how to do it.
Nachricht 10 von 12
Sahay_R
Your foundation walls should be of a particular type - select that under Type Name. Once this is done, apply the filter to the group, and override Lines to whatever color and pattern you need.
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
Nachricht 11 von 12
@tpreisler: Have you even tried what I suggested: Show Hidden Lines? This sounds like a perfect application for it. You want to see elements below ground displayed with hidden lines; right?
Nachricht 12 von 12
tpreisler
als Antwort auf: barthbradley
Thanks Mr. BarthBradley did try it but it's to much work the filters works better in my case.
