Filtering Key Schedules
4 REPLIES 4
DGraham1
1456 Views, 4 Replies
Hi all,
I am using key schedules to display generic information such as abbreviation lists, and I'm looking for a way to filter the schedule via an added yes/no parameter to allow project teams to filter out entries that aren't being used in specific project.
Is there a way to filter a Key Schedule? Or display only selected entries in a separate schedule?
Thanks.
Labels (4)
4 REPLIES 4
in reply to: DGraham1
No can't do. Altenately, you can use a noteblock or a keynote legend.
Almost sounds like you are describing filtering a Keynote Legend by Sheet...
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2015/EN...
_Vijay
Actually, you can filter after your scheduling.
Mohamed-Nassar
this session will help you, it's very useful
https://revitpure.com/blog/6-steps-to-create-efficient-plan-notes-in-revit
If the above reply answers your question; Please mark it with ACCEPT SOLUTION
Mohamed Nassar , ACP, Autodesk Ambassador Gold
BIM Support / Structure Modeler
Forma Design Contest
Technology Administrators
