Is there any way to Filter in Revit (e.g. Schedule Filter or View Filter) based upon Empty or Non Empty parameter fields? This is critical for non-numeric parameters.
Perhaps there's a special operator that works since * and ? don't...
Without an Empty/NonEmpty criteria, all other Criteria Arguements require at least one character to filter on, but it just makes sense that someone would want to filter either all elements that have or don't have empty parameters.
For Example: I have a custom PSI parameter for all structural concrete elements and I want to be able to turn off all elements that have a value entered. Since this is a Number parameter, I am able to setup Filters based-upon >, <, = criteria to show hide what I need (e.g. PSI Is Greater Than 1). But, I also use Comment parameters (i.e. Text parameters) that are structured and I have not found a way to Filter based-upon whether those parameter fields are empty or not.
All comments/suggestions are welcome! I've attached images of the available Criteria for Numerical fields and Text fields.
Gelöst! Gehe zur Lösung
Gelöst von L.Maas. Gehe zur Lösung
Often what will work is to say greater than and leave the value blank
Louis
Please mention Revit version, especially when uploading Revit files.
yes you can just leave the filter by: set to none. thanks
I want to filter by Assembly Mass with blank value (by defaut in REVIT) so I can use none.
my understanding you want to leave it empty? if yes set to none. thanks
By defaut REVIT don't add a value in parameter and I want to filtre parameter "Assembly Mass" where ther is no value.
If I put equal to 0, it doesn't work. How to do ?
It works for me here. I can leave the value empty and it works for finding empties.
I know this is a little past due, but this is an issue with the way Revit handles comparing numeric values (e.g. mass, volume, area, etc.), which I can't really blame them for. How do you compare 0 and an empty string ""? What do you set "" to? Null? 0? How do you know you're capturing the intent of the user?
You could use the same argument for when these parameters are, somehow, blank (e.g. when a room is "not placed"), except they know that these values are, essentially, 0, and that a user will want to filter based on whether these odd values exist, so they will have the value of either 0 or -1. If one of these parameter values is truly blank, then there is likely something else wrong, either with the file or the family, as Revit does not like leaving numeric values as truly blank.
So, these parameters require a value, but you should get the desired results by setting in the filters:
"<parameter name>" "<is less than/is less than or equal to>" "0". This works
If that is not the case, then there is likely something else wrong. If you still want help, let me know what family you're using (as I don't recall off the top of my head what contains an "assembly mass" parameter), and I can see what needs to be done.
