I am making an overview drawing of all the railing on a terrain. To distinguish the different types of railing from eachother, I used filters to give each their own color. However, sometimes I had to use several individual segments of the same type next to eachother. In the overview drawing this shows up as a continuous line. In the overview it has to be clear that these are separate segments. To achieve this, I had the idea to use a separate filter on the Start and End posts and have them show up as a black dot. When I apply the filter, nothing happens. (see attached) What could be the problem? Or is there maybe a better way to achieve my goal?
Any help is appreciated!
Johan
Gelöst! Gehe zur Lösung
Gelöst von FAIR59. Gehe zur Lösung
Yes all the balusters are visible in the view. The thing is, when I check all the boxes (see attached), then the override works for all the components of the railing( balusters, top rail etc.) I just can't seem to apply the filter to just one of them.
That does seems to be the problem either, I put the filter at the top and still nothing.
Considering:
I would say the Baluster Category shouldn't be in the filter Category list, and is there by mistake.
Add a detail Item to you end-balusterfamilies. In the detail item, draw the cut-profile and assign the SubCategory to a dedicated Category (p.e MyEndBaluster).
Hide the Detail-Item subCategory in "normal" plan views, override the subCategory in the overview drawing.
