Hi everyone,
I have been hitting my head against the wall for quite some time due to this issue that I have encountered.
I have several models linked into one model, in here I have created few filters to color certain items based on parameter, so far so good. I specifically have 3 filters, they all do the same things but based on a certain value they color items differently.
On of these filters do not work no matter what I try, it is set up the same way as the other two that work.
I have attached some pictures for clarity, I have simplified immensely the problematic filter, now it is only supposed to color one single item based on its value and somehow it is still failing in doing so.
Picture 1 shows the rule that I created, pic 2 shoes the property of the element that should be filtered, (they clearly match), pic 3 shows that if I do not use the filters but I just override the entire category (specialty equip) it works.
Does anyone have a suggestion? What am I doing wrong?
Best regards
Simone
