Fillet an ellipse shape
2 ANTWORTEN 2
GELÖST
Nachricht 1 von 3
991659842
293 Aufrufe, 2 Antworten
Hello everyone, I made an ellipse shape and filleted it, but I failed. I hope to find out the reason
2 ANTWORTEN 2
Nachricht 2 von 3
rxi.gg
als Antwort auf: 991659842
It's an issue Revit has with fillets and alignment. If you give 1 mm more to the fillet, it will do it without any problem.
Roi G. | AUTODESK REVIT & DYNAMO EXPERT
Da un "Me gusta" si la respuesta te ha resultado útil y acéptala como solución si ha resuelto tu duda.
Give a "Like" if the answer has been useful to you and accept it as a solution if it has solved your doubt.
Nachricht 3 von 3
991659842
als Antwort auf: rxi.gg
yes,it works,thank you!
