We have two nearly identical details. In fact, in the image, the detail on the right was drawn first, then the view duplicated and modified for the left detail. For some reason, none of the filled regions are filling on the left.
The plywood, gwb, and insulation should all have appropriate hatching like the right details. When new regions are created, they suffer from the same ailment, borderlines show, interior hatch does not.
All the visibility settings are the same
VG is set to show the detail items (all on)
Same Scale
Same Detail Level
Both in Hiddenline
Nothing is hidden on either drawing
Thank you.
Gelöst! Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
I duplicated the drafting view and the regions worked like normal.
Which is great and all for a workaround, but I am curious if we can fix the issue in the drawing.
Unfortunately, they are not overridden.
This might just be filed under "things with no real reason"
