Filled Regions: Concrete Doesn't Show Up As An Option
2 ANTWORTEN 2
GELÖST
Nachricht 1 von 3
liz.nahm1
266 Aufrufe, 2 Antworten
I am working on a Filled Region & need the region to illustrate concrete. I am thinking that maybe the Filled Region pattern options are different than the Fill Pattern options if I use Additional Settings on the Manage tab.  I'm a little confused on how to force the concrete pattern to show up as an option for my filled region, as it does not display even though it is used elsewhere in the model.  The pattern is not in any other filled regions in the project, but in walls, slab, etc.  I know that I need the desired pattern to show up in Filled Regions under Detail Items/Families, but am unsure of how to make that happen. See images below.  The 1st image is the fill patterns under Additional Settings & the 2nd image shows the Filled Region options available to me(a few are out of range, but none are concrete). Any help appreciated.
2 ANTWORTEN 2
Nachricht 2 von 3
liz.nahm1
als Antwort auf: liz.nahm1
Grr, Of course I found it right after I posted this.  I did search for the answer for at least 45 mins before I posted, I swear:\  Well, here's the link if anyone needs it. You just need to Edit Type essentially.
Filled Region: Fill Pattern
Nachricht 3 von 3
SteveKStafford
Filled Regions use Fill Patterns. If you don't have a Filled Region with a concrete Fill Pattern you need to duplicate an existing Filled Region, rename it and then assign the Fill Pattern.
Steve Stafford
