Filled Region transparent
Does anyone know how to make a filled region transparent
Gelöst! Gehe zur Lösung
Gelöst von aRcHiTeCt.JM. Gehe zur Lösung
Gelöst von Alan.johnson1970. Gehe zur Lösung
Right click on the filled region > Override Graphics in View > By Element.
And set Surface Transparency
… hi @Anonymous
…. Right click on the corner of the filled region
… turn that blue
…. At the same time you will be opening a dialog
…. Choose override graphics in view
… and could be element, category or filter
….. I ‘m choosing by element
…. In the dialog you can choose between HALFTONE… or surface transparency
… I just tweak this up to 54
… and click OK
…. There you have your transparency
aRcHiTeCt.JM
REVIT EXPERT ELITE
➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ is it working for you ? ➪ ⇩ 'Accept as solution' ⇩ ⇦
