some filled regions can be seen and selected in properties but not in project browser i.e. Families > Detail Items > Filled region, any reason or i simply missed something?
Gelöst! Gehe zur Lösung
Gelöst von ToanDN. Gehe zur Lösung
i noticed that the one not shown in PB don't have Identity Data, my guess is that one is upgraded from old version? how to fix it? i believe it's kind of bug and hope factory can look into it, i uploaded RVT FYI
I’m sure the factory has more important things to do. Why don’t you ask the users that ARE here to help?
thanks Toan, i copied from old (template) file, if it cannot be fixed then recreating template file from scratch is needed.
The filled region type probably comes from an old legacy template when the access via the project browser function wasn't made available. I would recreate the filled region type(s) from scratch or by duplicating from a 'normal' type.
