I'm trying to test this problem
Frist : I have family with filled region , (Pic1)
Seccon : Project, at floor plan i have floor and filled region (Pic2)
Three : When i load family into project, Filled region of family will back off filled region of project
I want Filled region of family "bring to front" of project !!!
1
2
3
Gelöst! Gehe zur Lösung
Gelöst von ralphdenhaan. Gehe zur Lösung
This problem is solved in the new Revit 2024 as an enhancement. You are probably trying this in Revit 2023 or earlier? Have you also checked Masking in the family?
Read here: https://help.autodesk.com/view/RVT/2024/ENU/?guid=GUID-429FCF55-2E7B-4B69-A3F1-2E625A93CE77
Select Accept as Solution and Likes are always welcome.
Ralph den Haan, (Lazy) BIM Specialist
