Filled Region in Drafting View not Printing Properly
4 ANTWORTEN 4
GELÖST
Nachricht 1 von 5
1181 Aufrufe, 4 Antworten
Hi All,
The filled region pattern display correctly on my screen but not showing after I plotted into PDF. I'm using Vector printing.
Thanks :leicht_lächelndes_Gesicht:
4 ANTWORTEN 4
Nachricht 2 von 5
RDAOU
als Antwort auf: Anonymous
@Anonymous
Seems to print fine here...tested both the built in PDF exporter revit 2022 as well as a 3rd Party exporter and a 3rd Party PDF Print driver...all same results
Can you share the drafting view which you have in an empty model?
Nachricht 3 von 5
als Antwort auf: RDAOU
Hi @RDAOU ,
Please see attached
Nachricht 4 von 5
ennujozlagam
just change your line weight to 1 and it will be fine. thanks
Nachricht 5 von 5
als Antwort auf: ennujozlagam
it works perfectly! thanks!
