Filled Region does not push thru to link
17 ANTWORTEN 17
Nachricht 1 von 18
CharlesBerteaux
1721 Aufrufe, 17 Antworten
I have an architectural model with a 2x4 Ceiling grid with a model pattern applied, looks and works just fine in the Arch model. This Arch model gets linked into a Mechanical model, and now the pattern is not matching the Arch, we have tried the following:
  • Remove filters
  • Removed and re-linked
  • Set up specific views in Arch and point Mech at that specific view via VG
  • moved linked model and put back in place
I have no idea why this happens, there is no good explanation, can any one help.
thanks
Charles Berteaux Iv
Revit Guru / BIM360 Guru
Autodesk Expert Elite
Autodesk Certified Professional
Charles Berteaux Iv
EDT BIM/VDC/Technology Department Manager | SSOE Group | Hillsboro
www.ssoe.com
17 ANTWORTEN 17
Nachricht 2 von 18
als Antwort auf: CharlesBerteaux
VG > Revit Links tab > Display Settings = by Linked View: choose the intended view from the list.
Wait a minute, you are talking about a material surface pattern, not a filled region.  Try Transfer Project Standards > Materials from the Arch model to yours.
Nachricht 3 von 18
CharlesBerteaux
that is the 3rd thing i tried. no luck
Charles Berteaux Iv
www.ssoe.com
Nachricht 4 von 18
CharlesBerteaux
haha, you response was to quick...i will try that. dont know why i didnt think of that. Ill post back after I try.
Charles Berteaux Iv
www.ssoe.com
Nachricht 5 von 18
cbcarch
The exact same material must be in both models--thus Transfer Project Standards>Materials.
Cliff B. Collins
Registered Architect The Lamar Johnson Collaborative Architects-St. Louis, MO
Nachricht 6 von 18
CharlesBerteaux
als Antwort auf: cbcarch
Sadly that did not work :enttäuschtes_Gesicht:
Charles Berteaux Iv
www.ssoe.com
Nachricht 7 von 18
What happened when you transfer the materials over?  Any warnings?
Nachricht 8 von 18
CharlesBerteaux
als Antwort auf: ToanDN
there was, and i chose to overwrite it. that did not work, so i also deleted the material in question out of mech model, and re-transferred it back in with no success. this is definitely goofy
Charles Berteaux Iv
www.ssoe.com
Nachricht 9 von 18
Try to transfer Fill Patterns as well.
Nachricht 10 von 18
CharlesBerteaux
Did that as well :zwinkerndes_Gesicht:
Charles Berteaux Iv
www.ssoe.com
Nachricht 11 von 18
How was the model linked? Did you acquire coordinates?
Nachricht 12 von 18
CharlesBerteaux
it is one of several buildings on a master campus, where they are all by shared coordinates. I thought about that as well, as i have seen patterns move based upon different locations, even in the same model. but not in years.
Charles Berteaux Iv
www.ssoe.com
Nachricht 13 von 18
RobDraw
I'm not sure if this is related but I've seen similar posts that end up being the "look up" / "look down" setting. The grids were different depending on the view orientation.
Rob
Nachricht 14 von 18
Do they have different ceilings in different Design Options?
Nachricht 15 von 18
CharlesBerteaux
Nope, Nope, and Nope....
I think its gremlins...
Charles Berteaux Iv
www.ssoe.com
Nachricht 16 von 18
RobDraw
Enough guessing. Post a portion of the model that exhibits the behavior.
Rob
Nachricht 17 von 18
CharlesBerteaux
als Antwort auf: RobDraw
Sadly, due to NDA, and IP nature of the client, I am forbidden to post pics, or even the native file for review. I do apologize, and i would really like to keep working for they who must not be named.
Let me see if i cannot duplicate this in a non IP environment that i can share.
Charles Berteaux Iv
www.ssoe.com
Nachricht 18 von 18
RobDraw
We only need a ceiling that exhibits the behavior and the naked file that it is linked to. Shouldn't be very difficult to strip out any proprietary data. Just saying that this sounds like something that could be solved with an example, not the contractually blocked stuff.
Rob
