Is it possible create filled region by a specific jpg like superhatch in autocad?Thank you
hi
You can use the materials and the use of Jpg format.
And for what purpose you want??
thank you for answer.But materials are seen only in realistic view.But ı want to work in shaded view?
In each mode to display JPG ,Must use realistic.
I am wanting to use either a filled region or a graphic override using a jpg image (for example laminate flooring, water in a pool or tiles on a floor) in plan view, for presentation purposes. Is this possible, or a work-around available? TIA
- Duplicate the view and use Realistic visual style
- Use materials or decals for the applicable elements. You can isolate them if need be.
- Overlay both views on a Sheet
