Filled / Masking Regions not visible in project
3 ANTWORTEN 3
GELÖST
Nachricht 1 von 4
Sahay_R
2492 Aufrufe, 3 Antworten
Has this happened to anyone? A filled / masking region does not show up when dropped into a project plan view. But when I drop one into a virgin project with the same view template, it works perfectly.
Points that were checked -
1) Active and visible Workset
2) In View Template - Detail Items are turned on
3) No filters
4) Even switching/removing the template did not help
5) Visible lines were used to sketch the outline
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
3 ANTWORTEN 3
Nachricht 2 von 4
Sahay_R
als Antwort auf: Sahay_R
Figured it out - it was a rogue filter that was getting in the way. Removed it and all worked properly again.
Rina Sahay
Nachricht 3 von 4
What kind of "rouge" filter ?? i have the same problem but cant finde any filter for it??
- Nicolai
Nachricht 4 von 4
ennujozlagam
Virgin project? Nice word. :Gesicht_mit_Freudentränen: Lol... Thanks
