Fill region in detail is masking where it shouldn't
11 ANTWORTEN 11
Nachricht 1 von 12
4310 Aufrufe, 11 Antworten
I'm trying to create a detail with an online formed with a filled region (with no hatch i.e. transparent) and correctly set to the top layer with display order. All looks fine in the detail family editor, outlines the detail etc.
When the detail component is brought into a project environment, the same filled region behaves like a masking region and obscures the detail beneath. If I wanted this behaviour I would have set the filled region to a solid hatch white, or used a masking region?
Is it possible to retain the transparency of a filled region in a project environment?
11 ANTWORTEN 11
Nachricht 2 von 12
JasonKunkel
als Antwort auf: Anonymous
Draw Order of annotation elements in loaded components can be... iffy... So even if you have the draw order right in the family, it may get messed up when you load it in. Do you have a masking region anywhere in that component? It might have moved up the ladder a bit.
I found this post that might have a quick workaround, if that is the issue:
https://forums.autodesk.com/t5/revit-mep-forum/draw-order-in-generic-annotations/td-p/5127638
Another solution I have seen, which takes more effort, is to create sub-detail components with your filled regions and load those into the "main" detail component. Those tend to behave better with draw order.
Jason Kunkel
Senior Practice Manager, Architecture and Engineering
CADD Microsystems Blog
RVIT Blog | Twitter | LinkedIn
Nachricht 3 von 12
als Antwort auf: JasonKunkel
Hi Jason
Thanks for getting back to me. It's not a display order issue. please see the attached screen shots. I just don't think its possible to set up a transparent fill in the detail component environment and bring it into the project environment without it acting as a solid hatch or a mask?
Is this a bug?
Thanks Brad
Nachricht 4 von 12
Did you know that if you uncheck Draw in Foreground, Detail Items can be placed on named Ref. Planes that are above or below other Details/Ref. Planes?
Nachricht 5 von 12
Fill patterns in the Project will override same-named fill patterns in the family.
Nachricht 6 von 12
JasonKunkel
Was just gonna say what was posted above - make sure you don't have a Filled Region type with the exact same name in the project. The project's type will win and replace the component's type settings..
I did a test with a type that is NOT in the project and was able to get the results you wanted:
Family Editor:
Family editor viewFamily editor view
Project viewProject view
Jason Kunkel
Nachricht 7 von 12
als Antwort auf: barthbradley
Hi. Thanks for the replies. I've just checked and the project doesn't have a pre loaded fill pattern which may be overriding it. Where is the draw in foreground checkbox please?
Thanks Brad
Nachricht 8 von 12
Hi, I get the same result if I use a crosshatch pattern like you're using there. If there is 'no' hatch pattern however, the behaviour should be transparent? It seems as though it defaults to a solid hatch if no hatch is specified and it isn't possible to have a transparent fill carry through the project?
Nachricht 9 von 12
I suppose I could create a hatch pattern with a single pixel as a workaround?
Nachricht 10 von 12
Thanks Brad
No problem, Brad.  Smiley (zwinkernd)
I'm speaking about the Draw in Foreground Parameter for the actual Detail Item you are drawing. Check it's Properties.
Nachricht 11 von 12
Hi. I am having the same issue with Solid Filled Regions nested in DI Families. It looks like a software limitation.
BTW. The Draw in Foreground parameter is available only in the Family Editor when you are creating or modifying a 3D family. Not in DI Families.
Nachricht 12 von 12
FCG-Alex_Acosta
Change visual style display?
