Fill Pattern Line Weight
Crow_T_Robot
Crow_T_Robot
I have read multiple posts regarding fill pattern line weights, but I cannot seem to find a definite answer. I know that Revit uses line weight "1" by default for fill patterns. Is there a way to modify the line weight of a specific fill pattern associated with a material? I know this is possible with "filled region", but going around using "filled region" on every wall of a different material defeats the purpose of Revit. For example, on my front elevation, I have a brick wall and wood siding wall connecting with one another. I want the brick fill pattern to have a different line weight than the wood siding. How would I go about this? Thanks for your help!
-Stephen Revit 2022 Intel(R) Core(TM) i7-8700 CPU @ 3.20 GHz, 16.0 GB Ram, NVIDIA GeForce GTX 1050 Ti, Windows 10
Replies (11)
Well well well... you may need to contact the OP of this thread and find out how he did it.
https://forums.autodesk.com/t5/revit-structure-forum/hatch-lineweight-heavier-and-lighter/m-p/106706...
Sounds like you want to a model surface pattern for brick that has double lines delineating the grout in-between the bricks .  With Thin Lines turned OFF, those double #1 lines would almost look like one line, depending on the View Scale.
Crow_T_Robot
Hi @ToanDN
Thanks for pasting the link to that post. Yes, I will reach out to the author. In the meantime, do you know of any way to achieve the desired effect? Also, seeing as you are basically a god on this forum, I would love to know how you approach this in your projects, and specifically your elevations. Is this something that you have a workaround for? Or are all of your fill pattern line weights the same, and it's just something you live with? Thanks for all of your help!
Crow_T_Robot
Hello @barthbradley
Yes, you are correct, that is the issue I am facing. Some of my pattern fills include lines that are very close to one another. These patterns need to have a lighter line weight to appear properly. Any idea how to achieve this? Thanks for your time!
@Crow_T_Robot wrote:
Hello @barthbradley
Lighter? That has nothing to do with Pen Weight.  But, Line Weights can be changed via Additional Settings=>Line Weights.  In this case, you want to change Pen #1.  But you probably already know this; don't you?
Maybe don't use patterns that have lines too close to one another?  Or make lineweight 1 very thin so it works on any patterns?  You can also submit the idea to Revit Ideas board.
Crow_T_Robot
@barthbradley Sorry, I mean "thinner" not "lighter" line weight, I've heard it referred to this way before. Yes, I am aware that you can change pen #1. However, the problem that I am running into is that I want some fills to contain thicker line weights, and some to contain thinner line weights. I will create a "wish for this item. Thank you!
Like this?
RDAOU
@Crow_T_Robot
The only way to do that at present is
  • Applying View Filters
    1. Instead of applying pattern to the Material, set it to none
    2. Add a Filter that uses Type Name
    3. Apply Surface Pattern override
    4. Pattern in the view will follow Object Style Projection Lines Line Weight
  • Phase Filters/Phase overrides.... (not sure how convenient that is creating a phase just for pattern graphics overrides)
Hello @barthbradley
Crow_T_Robot
Thanks for the video @RDAOU !
This seems like the best option!
