Fill Pattern after renaming doesn't show
4 ANTWORTEN 4
Nachricht 1 von 5
mairh_tsek
698 Aufrufe, 4 Antworten
Hello all,
I realise that after renaming some fill patterns they are not show up. In the same view if I choose a pattern which  I did not change the name it works.
Do you have face a similar problem ?
Thank you in advance!
4 ANTWORTEN 4
Nachricht 2 von 5
RDAOU
als Antwort auf: mairh_tsek
@mairh_tsek
Like this you mean?? If I rename, the patterns do not disappear
Nachricht 3 von 5
Check view's filters and see if they are based on filled region type names.
Nachricht 4 von 5
How are you "Renaming" a Fill Pattern?
Nachricht 5 von 5
mairh_tsek
als Antwort auf: RDAOU
this is what I did.. maybe it was a bug..I had the problem in the view in which I used some filters
Thank you!
