Phases - you could use graphic overrides in phasing, setting the new wall thickness as future and setting the material to transparent, adjusting its lines cut and projections.
A resposta te ajudou? Não esqueça de curtir e aceitar como solução!
Vitor Bortoncello | Arquiteto | Especialista BIM
Autodesk Certified Professional
