Hello all,
Is it possible to fill a family instance parameter with Dynamo. I have one type of family multiple times, and I want each element to have a different value of parameter.
Is it possible?
I tried the following but I get an error.
Thank you in advance!
Gelöst! Gehe zur Lösung
Gelöst von onuresen50. Gehe zur Lösung
I made a Dynamo script several weeks ago and it was working, I didn't understand what kind of script you want to make but I guess it has similar steps with mine. So maybe you can find what you need in my sample script.
Also rather than a Code Block, you can use a String and don't use " for a parameter name
Hope it helps
Thank you,
Rather than Code block I used string and it works.
The parameter is a Family instance parameter.
Just a question,
I noticed after the run of Dynamo, if I go to Revit and delete the value of the text parameter (that came automatically from Dynamo) and after run once again Dynamo, the parameter in Revit remains empty. Shouldn't be filled once again automatically?
Or if I change the parameter name input the second time , in Revit I get the results in the parameterName that I had during the first run and also during the second time.
Thank you!
Yes like you said, it should fill automatically again and replace the text each time.
Did you change Code Block to String for value too? or did you change it only for the parameter name?
For the first example It is ok, maybe I missed something.
For the second example that I gave :
Image 1 : 'Comment' parameter Name
if I replace the 'Comments' string with 'Mark ' string and run again Dynamo the result appears in both 'Comment' and 'Mark' - Image 2
After running Dynamo once, when you made a change on Dynamo and run again, it makes a new input in your Revit. it doesn't undo the previous input
Nice question, sorry I don't know it also ![]()
I will write you back when I learn it
