Filesize indicator
2 ANTWORTEN 2
Nachricht 1 von 3
yes_and_no
239 Aufrufe, 2 Antworten
Filesize indicator
We kept the project file under 2gb by save as.
Is there a filesize indicator somewhere or shortcut key or command like AutoCAD so we can get the current filesize without doing the save as ?
2 ANTWORTEN 2
Nachricht 2 von 3
a_meteni
als Antwort auf: yes_and_no
Have you tried the Autodesk Model Checker for Revit?
You can modify the thresholds to match with your project needs and you can include the file size  indicator in Revit Splash screen as well.
Nachricht 3 von 3
handjonathan
Hi @yes_and_no
Thanks a lot for posting your question to the forums!   Has the solution suggested by @a_meteni helped with your issue?
We look forward to hearing back from you with more information so we can help you as a community! 
Jonathan Hand
Industry Community Manager | AEC (Architecture & Building)
