Hello, I have a Revit 2024 file that I made on my laptop previously (last saved about a month ago), but for some reason I needed to have my laptop fixed so I borrowed a friend's laptop to continue doing some work.
I copied my saved files to an external hard drive and proceeded to open Revit 2024 on my friend's laptop, but every time I try to open my file, it shows up a blank page on the software, that would later on become unresponsive. I've tried uninstalling and reinstalling Revit, making sure no links are included in the Revit file. I've checked it on my laptop and it opened my file normally, but on my friend's laptop it won't.
Here are some specs if you need them:
My Laptop:
- GTX 1660ti
- 8GB Ram
- Intel Core i7-9750H @ 2.60 GHz
My friend's laptop (the one who can't open my file for some reason):
- RTX 3060
- AMD Ryzen 9 5900HX with Radeon Graphics 3.30 GHz
- 16GB Ram
I've also attached the file and some screenshots if it helps. Thank you!
File opens fine on my side. Can you open a new project on that notebook?
Its 2024.2
Ive been using this file to my desktop which is also 2024.2 then at home ive been using it to my nitro 5 which is also 2024.2 and then i bought a new laptop zephyrus g14 it wont open. Especially files that is 200mb and higher. I really dont know the problem
If it was 2024.3 I would say no. For 2024.2, I am not sure. Wait for the other users to answer in the forum.
Hi i do have the same issue and i tried to open your file with my laptop i encountered the same issue but when i opened it to my desktop it works fine. Both of my desktop and my laptop have the same specs
