File Tab Delay 2022
8 ANTWORTEN 8
GELÖST
Nachricht 1 von 9
Triguy04
506 Aufrufe, 8 Antworten
File Tab Delay 2022
I'm running Revit 2022. When I click the FILE tab it will literally take up to a minute before the pulldown menu opens. I will usually have to click the tab 2 or 3 times before it actually works. It's getting worse and worse. Anyone else have this issue and/or have a solution to fix it?
8 ANTWORTEN 8
Nachricht 2 von 9
als Antwort auf: Triguy04
- Close Revit
- Open c:\Users\[yourname]\AppData\Roaming\Autodesk\Revit\Autodesk Revit 2022\Revit.ini
and delete all entries under [Recent File List] and [Recent Workset List], save
- Open Revit and see if any improvement
Tags (1)
Nachricht 3 von 9
alan.johnson7YLND
Have you applied any updates / hot fixes?
Nachricht 4 von 9
Triguy04
als Antwort auf: ToanDN
That seemed to work. Will this be a permanent fix or will I have to do this when ever the "Recent List" gets longer?
Nachricht 5 von 9
Triguy04
als Antwort auf: alan.johnson7YLND
Yes, I've installed every update for 2022.
Nachricht 6 von 9
It fixed it permanently for me at least.
Nachricht 7 von 9
Triguy04
Ok, Thanks, I'll keep my fingers crossed.
Nachricht 8 von 9
ron_adst
Thank You!!!!
And when will Autodesk fix this total annoying waste of time?
Nachricht 9 von 9
RSomppi
als Antwort auf: ron_adst
If you understood why it is happening, you might realize it can be user generated. Your issue may be related to the recent files list(s) and changing paths or deleting files that may be in that list.
Search for resetting the recent files list and you might be able to fix it yourself.
