File Size
2 ANTWORTEN 2
Nachricht 1 von 3
pablo_pintoCDNZU
167 Aufrufe, 2 Antworten
File Size
I am having problems with the file size, when workin in a colababorative mode. I created a central model, in a One drive cloud. The file size is about 95 Mb, which is normal. However, the use of cloud storage is about 34 Gb. Does anyone knows what is happening and how can I solve this problem?
2 ANTWORTEN 2
Nachricht 2 von 3
Is that the usage on the Cloudstorage or the Filesize on the cloudstorage?
If it's the usage, it could be somewhat possible with the addional files generated by a Workshared model, but 34Gb seems a bit off, maybe included the versions in the cloudstorage itself is also counted?...
Ps. A workshared model can be created and worksed on in a OneDrive share, but I wouldn't recommend it.
Nachricht 3 von 3
Thank you for the answer :daumen_hoch:
