File open hangs for quite sometime
2 ANTWORTEN 2
Nachricht 1 von 3
Ken.HeinzESP2B
269 Aufrufe, 2 Antworten
In Revit 2018 , 2019 or 2020 - When I choose File open and try to browse from the Look In section at the top, Revit will say not responding for about a minute then will eventually find the drives.
Any ideas why?  I have completely uninstalled and reinstalled as well deleted the Revit.ini files.
Very frustrating - Other non AutoDesk products are not experiencing this.
Thanks in advance
2 ANTWORTEN 2
Nachricht 2 von 3
Mirko.Jurcevic
als Antwort auf: Ken.HeinzESP2B
Looks to me like Revit can't find some network drives. Similar happened to me before.
You said that you deleted Revit.ini file. The thing is that you must not delete Revit.ini files but edit them (means: open with Notepad or Notepad++) and delete everything between:
[Recent File List] and
[Recent Workset List]
Do not delete [Recent File List] and [Recent Workset List], just the content between them.
Save the ini file.
Run Revit.
If you just delete Revit.ini file, Revit will generate it again once you run it.
Revit ini file locations:
%appdata%\Autodesk\Revit\Autodesk Revit 2018
%appdata%\Autodesk\Revit\Autodesk Revit 2019
%appdata%\Autodesk\Revit\Autodesk Revit 2020
If this solved your issue, please Accept it as Solution help other forum users with similar issues to find answers easily.
Mirko Jurcevic
My blog: www.engipedia.com
Try my Revit add-ins: Autodesk App Store
Nachricht 3 von 3
Ken.HeinzESP2B
als Antwort auf: Mirko.Jurcevic
Thanks for the reply, I made sure I deleted all the lines in between and it still hangs. Its not seeing the network drives quickly like it has to discover them first. I did notice that even if I go through my PC on the side and look at the network drives, it cant find those either for a little bit.
