FILE NOT SAVED
FILE NOT SAVED
Message 1 of 11
FILE NOT SAVED
Hi, I am using Revit 2018 and i keep getting this error FILE NOT SAVED. This is happening all the time and i keep losing heaps of work. Can anyone please help?
Regards
Replies (10)
Message 2 of 11
Is you file local, hosted in a server, on a cloud?
Message 3 of 11
Are you trying to save while in an editing mode of something?
Message 4 of 11
I have tried both on the server and local drive, I still get the same error.
Message 5 of 11
I have tried closing all windows except current and made sure I was not editing any views.
Even tried having either model or drawing sheet open and everything else closed.
Message 6 of 11
You sure is isn't a permissions issue?  (e.g. you opened a write-protected file)
Message 7 of 11
I have administrator right on my PC.
Message 8 of 11
Files/Folders can still be write-protected.
Message 9 of 11
I have checked and it doesn’t say protected under properties, I have also tried to save as in a different location.
Message 10 of 11
Edit your anti-virus, anti-spyware sperm whale whatever and add Revit and their file extension to the white list.
Message 11 of 11
Anything else said in that Dialog Box other than "File Not Saved"?
...and you are sure you don't have a command or add-in running in the background?
