Hey
I downloaded my Revit File from my email and started working, I'm not sure where did I save the file, I think it was in the Downloads, then while working I started saving newer versions with newer names. I finished the work and I'm sure I saved it but still not sure where!! today I'm trying to open the files, but I found them on Revit Open Recent but I can't open them!! the file path is : AppData\Local\Packages\Microsoft.MicrosoftEdge………..\TempState\Donloads\Project
and when I search about the files in the documents I couldn't find them
Try a wider search. Search your whole hard drive .
...Can't you just download it again? Also, don't your personal downloads go to the "Download" folder by default?
I'm using a Windows 10 Computer and it seems that my Downloads folder clears files, because I couldn't find any previous downloads.. and I guess my Revit files were saved to Downloads, I don't know if there's a solution ![]()
