To whom it may concern,
This is more a technical issue, but involves a Revit 2017 file. I wanted to show a Revit file with a projector. Everything was fine until I tried to save the file and I got a message saying something like: All commands in Revit can be used except the following ones: Saving the file, etc. Did somebody experience the same issue? Any comments will be highly appreciated!
Kind regards,
José Luis Bermúdez Alcocer, Ph.D., M.Arch., B.Arch.
No, I do not have the Revit Viewer 2017. It is weird, because I changed from the "duplicate" mode to the "only projector" mode. Then, I can save the files.
Kind regards,
Hi ToanDN,
Everything was fine the next time I used the projector. I can see the Revit file and save it and still show it with the projector. Thanks for your answer!
Kind regards,
