File corrupt when auditing
4 ANTWORTEN 4
GELÖST
Nachricht 1 von 5
398 Aufrufe, 4 Antworten
I have a 2018 Revit file that will open without an audit but will not open when an audit is run on it.  All the backup files are corrupt too so I'm not sure how long the file has been corrupt.  I have tried going into the journals and try that fix, I've tried everything that I could google on here.  Can anyone tell me how to get a clean central file?  I don't have any backups to use because they are all corrupt too. How can I send this file to Autodesk and see if they can fix it
4 ANTWORTEN 4
Nachricht 2 von 5
als Antwort auf: Anonymous
Make your way to the rooftop and turn on the "Batman" signal.
...or, yell "@Viveka_CD"!!!
Nachricht 3 von 5
Viveka_CD
Hi @Anonymous
Thanks for posting on the forum.
Which Revit version do you use?
Can you send us your Revit file and journals to troubleshoot further?
Also, what steps did you try?
Looking forward to your reply update.
Nachricht 4 von 5
als Antwort auf: barthbradley
I found directions online and was able to fix it.  I had to create a library so I knew which families were corrupt because it crashes at the corrupt family.  Thank you for your offer
Nachricht 5 von 5
Viveka_CD
@Anonymous
Good to know. Sharing this article on Corrupt families within the model to benefit others seeking similar solutions.
Also, it is good to updated to the latest build
Tags (1)
