Unfortunately , could not use licensed product received from Autodesk at June 17, since 30 June. Software is having constant block message about Fault 22 located ADLs that do not give any possible option to open it for work.
Nothing is help to prevent from this message, nothing removing it and software is blocked from use.
I did try tips to run and properties applications and several more from the Forum. I do not know what exactly yet might be to try to solve such a problem.
If such casualties consider Asure, so might be a something to remove it from Autodesk products, permanently.
