Fatel error when exporting NWC to BIM360
0 ANTWORTEN 0
Nachricht 1 von 1
Bjorn.Sadones-itd.be
270 Aufrufe, 0 Antworten
Whenever I try to make a NWC export in Revit, and I choose where to save the file. The moment I click on the BIM360 icon, my revit crashes.
My colleagues have the same problem with an other project same issue, both project are version 2018.
I have another project where I  do the same, there it works fine but this in the version 2020.
All files and models are on the BIM360. Naviswork files it self works fine. The model works to.
The NWF file is first made on the local drive then saved to the BIM360 and the NWC files are also first saved to local file then saved to BIM360 and then appended with the correct path.
So exporting to local C and then saving it back to BIM360 works but is an extra step.
In my 2020 project I can easily export to NWC click on BIM360, overwrite the file and press F5 in my NWF file.
Close NWC on load is pressed off so that’s also no issue.
Does someone have this same problem, or is this a real bug?
0 ANTWORTEN 0
