fatal error
2 ANTWORTEN 2
Nachricht 1 von 3
290 Aufrufe, 2 Antworten
fatal error
I do not understand how to correct this error
2 ANTWORTEN 2
Nachricht 2 von 3
Samantha-G
als Antwort auf: Anonymous
Hi @Anonymous
It is difficult to say why that error is happening with out the journal files.  I would recommend saving and having your BIM manager run an audit on the central file.  If it continues, I would make note if it is the same thing that is causing the error.  You could also role the file back if needed.
Sam G, CM-BIM
Revit Certified Professional
Nachricht 3 von 3
Revit crashed on you. It happens. What were you doing?
https://knowledge.autodesk.com/support/revit-products/getting-started/caas/CloudHelp/cloudhelp/2017/...
Post your Journal File.
