When I add layers to a certain wall and choose their materials, a fatal error occurs and Revit shutdown.
Kindly, give me a solution for this problem.
Seems there a corrupt file and few families in that..
use some other wall and recreate walls you need.
Identify which walls/families are giving problem and get rid of them ( delete and purge )
Cheers!
@Anonymous hello, try to install latest updates from autodesk and see if helps. thanks
