I recently downloaded Revit. In what folder will find families to load from?
Depends on which version of Revit you downloaded...the default path if you did not change it during install will be C:\ProgramData\Autodesk\RVT [VERSION YEAR]\Libraries
example:
For Revit 2022, you need to download the the Content Libraries separately either from Account management or from the following link https://knowledge.autodesk.com/.../autodesk-revit-2022-content.html
Did you download and install the content libraries? They are separate from the core content.
