Family Won't Tag
3 ANTWORTEN 3
GELÖST
Nachricht 1 von 4
paul_griggs2XXL4
309 Aufrufe, 3 Antworten
Family Won't Tag
Afternoon, All,
As per the attached screen recording, I cannot figure out how to tag this family. I have added a type mark into the parameters (within the project, not the family) and yet it won't show this when tagged. It just shows a question mark.
Any advise would be greatly appreciated!
Paul
Beschriftungen (1)
  • tags
3 ANTWORTEN 3
Nachricht 2 von 4
als Antwort auf: paul_griggs2XXL4
Are you sure the Tag is reporting Type Mark? Edit the Tag and see.
If it is, then I have a hunch you aren't tagging the right family. TAB-Select when placing Tag.
Nachricht 3 von 4
Hi @paul_griggs2XXL4,
Almost looks like you are tagging something else, it normally highlights before tagging.
Select the tag and then click "Select host", what's tagged?
Also does the tag have the type mark parameter in it's label?
- Michel
Nachricht 4 von 4
Thanks, both. Much appreciated!
@TripleM-Dev.net The tag definitely has the correct host, but I didn't know about the 'select host' option, so thanks for that. I am sure I will use that again in the future!
@barthbradley Spot on. Within the tag, I checked what the label is reporting, and it was reporting the type comments and not the type mark! See below:
Instead of revising the parameter in the tag family, I just added the tag reference in the type comments and it came up. I will check with the team in case they set-up the plumbing fixtures tag to read the type comments for a reason, and if not, I will revise the tag parameter to read the type mark instead.
Thanks very much, both.
Paul
