Family will not change type after load
I'm going through a tutorial on families (Paul Aubin) and have created a shelf w/ nested brackets that works as expected when flexed in the family editor.  Any project I load it into shows it at its default configuration, but when I select it in the project and change it's type in the properties box, the configuration does not flex - it stays as inserted.  It also shows my parameters in the properties box as individually modifiable.
Anyone know off hand what I'm missing?
Thanks.
fernanda.firman
Could you please post the family?
Fernanda Lima Firman
Technical Support Specialist
Customer Service & Support
Autodesk, Inc.
Revit Clinic
If this helped solve your issue - remember to 'accept as solution' to help others find answers.
Sure.
ryan.duell
Currently your parameters in the family are all set > “Instance”.
Modify the “Width”, “Thickness” and “Depth” parameters to be “Type” in the family instead. For an expansion on how instance parameters are remembered, which explains why they do not update in the project, see the post here:
http://insidethefactory.typepad.com/my_weblog/2010/12/perfecting-the-palette.html
Thank you,
Ryan Duell
Thank you!
