Family Visibility For Trim
1 ANTWORT 1
Nachricht 1 von 2
jdmwrxpower
153 Aufrufe, 1 Antwort
Hi everyone,
  • I am using an Anderson 400 BIM and there is a cornice top molding I made as a sweep within the family.
  • I want to be able to see the cornice top trim in 3d & elevations but not in plan view.
  • I went into the family and clicked on the cornice top and went to visibility settings and unchecked Plan/RCP though it solves my issue of not having the trim visible in the plan view it will also not be visible in 3d.
  • How can approach this properly to be able to control the trim view so I can see it in 3d and elevations but not in the plan view?
Thank you in advance for any help
1 ANTWORT 1
Nachricht 2 von 2
als Antwort auf: jdmwrxpower
It should be visible in 3D.
Post the file here so we can see what's  going on and tell you.
Or you can go through this list of 33 to find an answer:
https://www.revitforum.org/node/459
