I made a project and inserted a prototype for a family that I wanted to use. This family originally had 2 types. I went back and edited the family. Once I was finished with the family, I made more types that I needed for the project. When I reload the family, the shape is updated, but the types within the family are still only two. Is there a way to update this?
Quick question - when you reload the altered family, do you click on the bottom option?
Plan B - Try changing the name of the family (add a 1 or something) and load. Switch instances over to this family. The you can purge the old family.
When I load the family, no boxes pop up. I'd like to avoid the workaround as I have 90+ instances in the project which I then will have to change.
I found a workaround.
I went into the family and changed a dimension slightly. When I reloaded the family, it accepted the new types. I'll be using this method for now.
Thanks for your time.
...another way to do it, is to highlight the family in the Project Browser and click "Reload...".
