Family Type Nested Multiple Families
7 ANTWORTEN 7
Nachricht 1 von 8
412 Aufrufe, 7 Antworten
I am trying to get my family types, essentially the length parameter, to show up across 3 nested families.  My first family is the extrusion and length parameter via ref. line.  It is made up of a few different pieces which is why i used a ref. line.  The second family is to add a rotational parameter, this still has the family types of different lengths.  The third family is what will be put into a project and I would like to change the length / family type in the third family.  I have tried shared parameters but cannot see the desired result. Please see images below.
7 ANTWORTEN 7
Nachricht 2 von 8
als Antwort auf: Anonymous
Are we talking Instance Parameters? And, are you Associating Nested Family Parameters to Host Parameters?
Post the Families.
Nachricht 3 von 8
I just looked at your screenshots and it looks to me  like you are nesting Family TYPES.  If that's right, you should label the nested Family to a "Family Type" Parameter in the Host.   Are you familiar with these kinds of Families and how they operate?
See "Creating the Family Type"  section at this link:
https://www.cad-notes.com/how-to-control-family-element-visibility-with-parameter/
Nachricht 4 von 8
als Antwort auf: barthbradley
No I have not done anything with family type parameters before
Nachricht 5 von 8
Post your files. I'll show you.
Nachricht 6 von 8
Actually I have figured out a good way to fix my issue, thank you, however, I have another problem.  These families will be in a ceiling plane, and when I load the family into a project, I get a variant offset from the ceiling plane. I am not sure what could be causing the issue.  Please see attached.
Nachricht 7 von 8
Post the family or families.
Nachricht 8 von 8
I changed an older file and re-loaded it into the family, then into the project, seemed to do the trick.  Thanks!
