Family trying to open as Central Model
9 ANTWORTEN 9
GELÖST
Nachricht 1 von 10
chughes
447 Aufrufe, 9 Antworten
Has anyone seen an issue similar to this, where a family throws a local user file error when opening the family?  Any suggestions on a fix?
9 ANTWORTEN 9
Nachricht 2 von 10
als Antwort auf: chughes
The fix is spelled out right there in your screenshot.
Nachricht 3 von 10
chughes
als Antwort auf: barthbradley
You cannot save a Family as a Central Model.  This is a Family.
Nachricht 4 von 10
RDAOU
@chughes
So if you get this message when
  1. you go to File Menu >> Open >> Family >> Navigate to that RFA and open it?
  2. Or do you have some Content/Library management add-in which you use to open and/or load families into models and then this pops up?
Attach the family lets try from our end
Nachricht 5 von 10
chughes
als Antwort auf: RDAOU
I do.  This is just a Family living on our file server.  No special management in place.  File is attached.
Thanks.
Nachricht 6 von 10
RDAOU
@chughes
Edit - never mind previous reply it did prompt upon exiting... I will check it in a few but this is interesting because the whole family acts as if it is locked and no one but you can make changes to it (can make the changes but not save or save as)
You have just figured out how to lock/copy right/prevent changes to families lol
Nachricht 7 von 10
mhiserZFHXS
@RDAOU
Yea but can we recreate this? :grinsendes_Gesicht_mit_Schweißperlen:
Nachricht 8 von 10
Try this file.
Nachricht 9 von 10
RDAOU
als Antwort auf: mhiserZFHXS
@mhiserZFHXS
If you can figure out the cause, most probably yes...but that was a joke.
@chughes can bypass / get rid of the prompt as follows:
  1. load into a BLANK new model from an OOTB template and Delete original family
  2. Edit the one loaded into the new project
  3. Save As a new family
It must be something inherited from the original wokshared model it was saved from
Nachricht 10 von 10
chughes
Thanks much @RDAOU .  That fixed it.  No idea what happened.
