Family that attaches to roof
4 ANTWORTEN 4
Nachricht 1 von 5
1324 Aufrufe, 4 Antworten
I created a family under component and wanted to know if there is any parameter I can create that allows me to attach it to the roof?
4 ANTWORTEN 4
Nachricht 2 von 5
als Antwort auf: Anonymous
You can align the sketch linework of the geometry to the Roof in In-Place edit mode, but you can't attach it after the fact.
Nachricht 3 von 5
Edit the family, tick the box Work Plane, untick the box Always vertical.  In project, you can pick any surface to place the family.
Nachricht 4 von 5
dferreira-blackwell
you should have created face-based family
Nachricht 5 von 5
when you say "attach it to the roof", do you mean attach the component to the roof using the "Attach Top/Base" tool, or do you mean host it to the roof?   In other words, place the component on top of the roof.  If it's an In-Place Component, which is how I read you (because you said you created a "family under component"), you should have first picked and made current a Work Plane to sketch your component on. In this case, you would have picked the Roof Face as the Work Plane.
