Hi, As you see in attached my Washer Dryer family text shows off on the main floor, Although I put it on the basement floor. Thanks for any help.
Yep...the reason I hate labels vs using tags.
Your view range is probably set to go below to the basement. If you change it to just be the current floor they should disappear, but you may lose out on areas where you do want to see further (ie stairwells).
If I find them I just hide in view... drives me crazy on Roof Plans where I want to see the groundwork around the building too and I get all the darn labels from the OOTB families.
If you can change the View Range for the entire View then do it as @Anonymous suggested, then create a Plan Regions for the areas you want to look farther down. Or, keep the current View range as is, create a Plan Region covering the entire W/D equipment and change the View Range to shallower.
