Family Templates are installed but when using "Load Family" the folders empty.
7 ANTWORTEN 7
Nachricht 1 von 8
1277 Aufrufe, 7 Antworten
I am currently using a student version of Revit 2018, I was successful in installing the Autodesk Revit Content Libraries 2018. And I already checked the Template folders in the default destination when installed. They are intalled, but when I use the "Load Family" inside the revit, The Default Templates Folder are empty. Only the new contents for Revit 2018.1 are the ones can be loaded.
Can anyone help?
7 ANTWORTEN 7
Nachricht 2 von 8
rimacoca
als Antwort auf: Anonymous
Go to your explorer windows and copy the file path
Go to revit and paste the file path in the name field
Is showing the files?
A KUDO is always welcomed; However, when the above answer helps and/or clarifies your query; kindly mark this reply.
Submitted ideas
/ All Revit up dates
Projects BIM Integrated Services
Nachricht 3 von 8
als Antwort auf: rimacoca
It doesn't work. Even at first, I am sure that the file path of the installation path and inside revit load family are the same.
Nachricht 4 von 8
@rimacoca, I've notice, the supported files that can be load are ".rfa" while the defaults are .rft is there any way in changing them? or there is another way in loading them?
Nachricht 5 von 8
rimacoca
No.
But You can create new files from rft template and save as new rfa family file.
Go to revit and create a new family and chose the template file and save
Submitted ideas
Nachricht 6 von 8
rimacoca
The revit have two different folder
Template and library
You need the library folder :leicht_lächelndes_Gesicht:
Submitted ideas
Nachricht 7 von 8
I'm encountering the same problem. I have already tried your advice which is making an rfa file from rft file but even when I'm about to open a family, the rft file is also not showing in the Open window.
Nachricht 8 von 8
David_W_Koch
You cannot open an RFT file.  You can use one as a template to create a new RFA file.  If you look at your image, the file types being shown are *.rfa and *.adsk.
David Koch
AutoCAD Architecture and Revit User
Blog | LinkedIn
